dap35
I set my failsafe to throttle cut, self-level mode plus rudder. While I have not turned off my tx during flight, I did take my plane up, cut throttle and give it full rudder in self level mode and it worked a charm. A nice gentle decent in a circle.One possible way to combat losing signal, besides getting a better signal, is to use a gyro with level mode, like this one. If you set up your fail safe to neutral sticks, and then set up the fail safe for your gyro mode switch to level mode, then when you lose signal, it will level out and stay level as it glides down. I have one of my planes set up this way and I’ve bench tested it, but I don’t have the guts to try out IRL. 😂
Hobby Eagle A3 Pro V2 Flight Stabilization Gyro-HEA-AC-6472
valuehobby.com
