Robbie
Hey Guys,
Me and some mates are building a 3 meter Fokker Eindecker fighter foamy out of wooden dowl and depron.
We are using these plans, However have heavily modified them for the dowl frame
Foam Eindecker Top (2).pdf
http://www.rcgroups.com/forums/showatt.php?attachmentid=6949129&d=1405956091
Foam Eindecker Landing Gear (1).pdf
http://www.rcgroups.com/forums/showatt.php?attachmentid=6949128&d=1405956091
Foam Eindecker Fuse Side (2).pdf
http://www.rcgroups.com/forums/showatt.php?attachmentid=6949127&d=1405956091
Foam Eindecker Formers (1).pdf
http://www.rcgroups.com/forums/showatt.php?attachmentid=6949126&d=1405956091
Componants:
Motor: Turnigy Aerodrive SK3 - 4250-500kv
ESC: Hobby King 60A ESC 4A UBEC
Servo: Corona DS339HV Digital Metal Gear Servo 5.1kg/ 32g/ 0.13 Sec
Battery: Multistar High Capacity 4S 5200mAh
We are building a Wooden Frame which will then be covered in depron and reinforced with carbon spares
Now the frame is finished we are planning to cover it with Depron and then attach the wings.
If any of you have any advice or tips it would be much appreciated and I will update this post as the build continues.
Thanks,
Robbie
Componants:
Thanks,
Robbie
