okay @localfiend , Ive a question, would it be possible to provide a combined fuselage 1-6 into 1 stl and wing parts 4-7 LR also ??
Correct
Sorry, wouldn't be printable. A lot of the pieces, mostly on the fuse, are broken up to add strength and horizontal spars. If they were all combined, the prints would fail and you'd end up with a big mess.
Depending on what you're trying to do, you can combine stl's in meshmixer or similar programs.
You know that is a heck of an idea, never even thought of it. ThanksGot a 3D pen, you can fill that 2mm gap with filament with a 3D pen or well... reprint and cross you fingers
@localfiend , do you have a nose tip without the camera hole, please?
Really? I figure you would have at least one incremental backup run daily, and keep 3 months worth. A 6TB hard drive is less than $100, and worth having for times like this when such precious work is lost. A simple free solution I use is Cobian Backup (Windows). Start backing up today! We need you!Wish I still had the uncorrupted CAD files for this thing.
Thanks man, I appreciate it a lot.
It's like learning any new tool, there can be a bit of a curve. At least with the Prusa, you can be pretty certain that anything going wrong is your own settings or filament and not a problem with the machine.
If you're going to be printing a lot of planes, or more complicated parts, look hard at Simplify3d. It's a much more powerful tool, and it's also easier to share settings between people. The factory files I included in the downloads section on thingiverse make it easy to tweak stuff on batches of parts so you can get the best quality prints.
Looks like it warped on you a bit. Fortunately, that's a pretty small gap and you should be easily able to close it with just a little pressure when it comes time to glue things up. Consider using the helper discs (stl included in the downloads section) to help prevent warping on those really long and skinny parts.
All the left and right side pieces are identical, they're just mirrored parts.
Been looking for a small gap filler and found the Power Grab mixed with Acrylic paint for color does a nice job. Works great on plastic as an adhesive. Don't use to much as it adds weight.
I used a 3d pen to weld together some gaps when I assembled mine. It worked with pteg using the ABS temps. I haven't actually flown it yet though.Somebody somewhere mentioned a 3D pen ??
Hi Everyone,
Has anyone tried to print the entire front fuselage in one go? I mean stacking all the fus sections and printing them so you don't have to glue'em
I'm curious how/why the print would fail, and how strength would be lost?fuse, are broken up to add strength and horizontal spars. If they were all combined, the prints would fail and you'd end up with a big mess.
Just to share a little excitement, Banggood sent me 10mm carbon fiber tubes (instead of 8mm) after waiting 4 weeks. I have all my parts printed, so I just ordered from Amazon and got 8mm rods in 2 days. Now my wing is finally together! Regarding my two 10mm rods, well, I might as well print another plane that is 25% bigger with a 0.5mm nozzle. The math works out, and the parts fit my print bed, but does anyone have input on the 25% increase? Naturally I'll use a bit bigger motor & prop.
Hey @localfiend any idea why the supports inside parts aren't printing for me? Any obvious settings that could be wrong? I'm using cura. It's printing the outside shell and that's all... does anyone have ideas?
