telnar1236
In contrast to my last few projects, I've decided on trying to build an easy to fly jet trainer (first jet, not first plane) as my next plane. These last few years I've noticed that jets have tended towards getting bigger, more expensive, and more complex, pricing people who might want to fly jets out of even the smallest UMX ones. To that end, the idea with this project is to build a small, easy to print 4-5 channel jet as cheaply as possible that can be made entirely out of PLA if desired so that any printer can manage it.
It's designed to fly on a 50mm EDF. I'd like it to be 3s or 4s, but we'll see if I can get a 3s 3D printed jet to work out. The straight through duct with a large inlet should give a good combination of air to the fan and low drag. While this makes the plane look a bit chubby, I'm increasingly sold on the look and it's fairly ideal from a low speed aerodynamics standpoint.
The straight wings use a Clark Y airfoil which should give it very good handling and have 3 degrees washout from root to tip to prevent tip stalls (this is where 3D printing shines with more rigid filaments, because it's more rigid than foam and more precise than balsa, you can get very fine control over the geometry which can result in a locked in feeling plane). The tail is fairly conventional, and the plane is designed for 4-5 channel control with the full span ailerons being designed to be able to be used as flaperons.
