I just looked at your frame again. You'll probably want the biggest steppers you can find. I'm not even sure a TMC2130 can drive enough current for that monster. I suggest you build your gantry as light as possible too. That thing is going to be a lot of work to get good prints from. Add bracing wherever you can.
Thanks for the quick reply!!
The reason i was planning on going with NEMA 17 instead of 23 motors was to keep cost down, i also thought i wouldn't need it as the gantrys and effector are going to be REALLY light. I think the size of the printer is kind of misleading as the effector size is going to be the same as a smaller printer like a monoprice delta and the gantry kits are very light. Really the only difference between this and a normal sized delta is that the v slot tracks are longer and the timing belt is much longer. This is why i figured i don't need NEMA 23 motors but if i need them i have no problem trying to pick some up.
Here is why i believe i only need NEMA 17's
I am planning on now going with these as they have 85 oz of torque and are fairly cheap.
So each motor has 85 oz of torque.
Each gantry weighs in at about 5 oz
The effector without the hotend weighs about 1 oz
I can't find the hotend and volcano weight but i assume it is quite minimal lets say 10 oz for both.
(Edit: I just learned that the weight of the combined volcano and v6 is 4.09 oz which would bring the weight from 8.3 oz per motor too around 6.3 oz per motor)
With that math each motor is moving about 8.3 oz ( 5 for the gantry kit and then 1divided by 3 for the effector and 10 divided by 3 for the electronics on the effector) I think a motor with 85oz of torque should have no problem moving that as it is about 1/10 of its torque giving it a 1/10 power to weight ratio. Please let me know of that logic is flawed but from my perspective it should work out fine.
