Yesssss
Awesome!!!!
Doing some research on collective pitch/ variable pitch mechanisms. I will be limited in witch of the many methods there are that i can use. Material limitations as well as size and scale constraints aside I have 3ish mechanisms to to choose from. Since i dont want to get into through shaft linkages, im left with using heli style swash plates to liknk stationary control to rotational output.
Yeah, just a tad to complex, I am subbed to dark aero, my dream is to one day have a workshop where i can build a full size aircraft. Maybe at some point in the future i will do a tech demonstrator of this type of VPP at RC scale.Here's another reference for variable pitch as implemented on a full scale aircraft. This implementation electrically is probably a tad too complex for RC because it requires brushes and conductive tracks to transfer power to the variable pitch servo in the spinner. It might be possible to do with a PCB on the backside of the spinner and preloaded brushes on the plane itself.
Working on the front end assembly in preparation for the VPP, decided to go all out and hide all the VPP and RC componants inside a faux turbo prop engine case, since it will all fit. lol this 500kv heli motor looks so small. It should be powerful enough to swing the 20inch prop to 6.5k rpm. If i need to up the motor rpm and make an inline planetary gear reduction box then that is still an option. 80cc-100cc equavilent electric motors that normally are used for 20+inch props are just way too expensive.
I must say this is some of the finest rc modelling I have really ever seen. You must be doing this kind of stuff for a living right?(CAD)
I might need to buy a resin printer myself to build this beauty
I am not too sure, but the Freewing 8S 4075-1390kV Brushless Inrunner Motor looks like it fits most of the specs given.
Oh boy!!!!In the great words of Mike Patey. "WAHOOO" Draco RC: 06 The Mike seal of approval Premiers on the 1st of Jan 2021
HAPPY NEW YEAR EVERYONE!
Nice!Forward turbine case thing is roughed out, went back through almost everything and adjusted dimensions here and there, over all the case is narrower. The gear reduction now has correct tolerances AND MANUALLY SKETCHED INVOLUTE TOOTH PROFILES, that took 3hrs all by its self
the batter tray thing is gone, will have re make it in the new confined space. And the carbon tube engine frame got all borked from the changes I made, but i was up all night working on the gears and making said changes so ill sort it out tomorrow
HAPPY NEW YEAR EVERYONE! see you all tomorrow.
