This is quite a large build so I'd recommend thinking about the gear earlier rather than later. A few things I'd recommend considering:
- What AUW are you anticipating? Even a FB model at this size can easily hit 20+ lbs. You'll need to use gear that can handle that kind of weight and design the gear mount into the structure/spars for the wing to spread the load out.
- The Shinden has some pretty long legs and you likely wont be able to cheat much on them due to the need for ground clearance on the prop, particularly during rotation and landing. Off the shelf may be hard to find so you'll probably have to build your own struts.
- CF tube is light and strong but relatively brittle. You'll likely need to use pretty solid aluminum or steel tube, especially if the weight starts to get up there. You MIGHT be able to get away with big music wire struts but they will be heavy too. You'll need big wheels as well. Dave brown has a great line of large foam wheels that are really lightweight, but you can't leave the model sitting on them for long periods of time without getting flat spots. I'd definitely check them out.
- Whatever material you go with for the struts, the length, weight of the material, and weight of the wheel will likely mean you'll need a BIG retract unit. Hobbyking has some at reasonable prices, but I would look for ones that are rated for a fair amount MORE than you expect this to come in at. They need to be strong enough to pull up all of that weight.
- Consider WHERE you are going to fly her. The runway at Flite Fest last year was MUCH better than in previous years and many of us were able to fly heavy warbirds with wheels around 4". Previous years were much rougher. Who knows what the conditions will be next year. That field is rough though and your gear (particularly that LONG nose gear) will take a beating. Struts, Trunions, and mounts will have to be built to handle it. Think about oversizing the wheels from scale if you can.
As someone who has a 20lb P-40 model about the same size as this build I can tell you that getting reliable gear for her was a huge headache and in the end cost $$$$. A lot of $$$$
. If you want to fly her for more events than just FF and have her last you'll need to build her with this stuff in mind. You COULD make her a belly lander, make the lower portions of the wing vertical stabilizers "breakaway" so they slide off on landing, and run a folding prop. Would save a TON of weight and complexity. You could then use a bungee launch setup to get her airborne (to keep yourself or a volunteer away from that prop).
Just my 2 cents. I'm happy to discuss landing hear options. Just let me know if you have questions and want to bounce ideas off the community.
