quickqestion
Long story short, I made the poor decision of buying an ESC from Ali express and it backfired. I bought a 4 in 1 30 amp esc and paired them with some Aokfly motors (they are actually really nice, I recommend them). But 1 of the 3 escs only kinda works but it makes a really raspy sound (as if there is gravel in the motor) when you add power, plus it takes way more throttle input to make it spin at the same rate as the other escs. The motor also only jitters until about 20% throttle and then finally starts to actually rotate, but the other 3 escs work perfectly fine.
I'm thinking it's some kind of timing error but I don't really know where to look. Any tips would be helpful.
Thanks
Links:
https://www.aliexpress.com/item/BS4...273.html?spm=a2g0s.9042311.0.0.3da24c4dEEZB49
https://www.aliexpress.com/item/220...94.html?spm=a2g0s.12269583.0.0.75d8450aM5ud0r
Thanks
Links:
