I didn't think about that side of things, only the "if the wing will be strong enough" side. Why does it need so much pull tension? Thanks for bringing this to my attention!
In that case, you've built that wing strong, I wouldn't worry about it. The forces will be high, but she should take it fine.
When maiden time comes, you can always start with an "up-start", which is effectively a scaled-down high-start for practice and trimming. IIRC, they're 1/3 the rubber and 1/2 the line, but I've never seen a consensus on that. The Upstart can give you a shorter pull into the air, and by starting easy, be a bit kinder to the wing. At full extension the acceleration will be just as high, but the burst won't last nearly as long. If she takes the upstart without flexing her wings under the strain, the full highstart should be fine.
That and a glide-toss into the wind should still float well for early trimming. Keep plugging away at her. She'll do just fine
