Jackson T
Hey guys, I like to create design challenges for myself when I build. On my last build, the Balsa Baby Baron, the challenge was to make a extremely portable plane, so it would fit easily into a backpack without being prone to damage. This time, it's size. I like motor gliders, so I decided to make my next project a HUGE motor glider. Because the wing is so big, I decided to make it a 3 piece wing with aluminium and balsa wing joiners for transport. I've just finished designing it, so now it's time to start building!
Specs:
Wingspan: 400cm (157.5 in.)
Length: ~170cm (67 in.)
Wing Area: 93dm2 (1441.5 sq. in.)
Aerofoil: SD7037
Estimated Flying Weight: 1500-2000 grams (53-71 ounces)
I've already cut out some ribs and the forward fuselage pieces, which will have longerons running off them down to the tail. The balsa I buy from my local hardware store is only 915mm long (36 inches), but my longerons have to be a bit longer. I'm going to have to join two longeron pieces together somehow. Any ideas on how should I do the splice joint?
I'll get some build pics up soon!
Specs:
Aerofoil: SD7037
