LocalFiend,
I'm back! I'm getting ready to start gluing the pieces together, but I'm a little confused about 2 parts. Namely, they are the down thrust piece and the fuse support. I'm not sure where they go and how. I'm assuming the marks suggest to remove the foam in the hashed areas, or is it a particular A, B, or C type fold? Any info will be helpful.
Is the CG still at 2"?
I'm planning on trying to put the ELE and RUD servo in the back closer to their respective surfaces. This will result in a shorter rod length and flex. I think it will give me more space in the power pod battery compartment area. I like your plans where I can take the top off and install the battery. I'm tired of taking the power pod out and having to put it back in.
I started to try to learn how to use Adobe Illustrator so I maybe able to make skins for my future builds including yours. I can't say I'm at the same level of Rastersize, but I'm striving to be so. My skins are more basic than his, but I'm still learning. I try to study his plans to learn how he did something and/or get ideas on how to improve ones I've done so far. Here are a couple of screen shots of the skins I printed out and will be using for the 42" Zero.
The power set up I'm going to use is based on the FT Racer/Ripslinger I used on the past. The motor is a 3536-1400KV with a 8x4 prop. The ESC is a 60a and the battery is a 4s 2200mah 35c.
I can forward both the PDF of the skins and the illustrator file if you like.
BTW, my/your micro zero still is in one piece. She flies fast! I still get a kick out of it. Several of the other guys have a micro mustang and P-40 and they try to chase me down like its WW2!!!
Thanks for all you have done and thanks for all the inspiration!
Greg C
