Battery800
Your best bet is to search for racing drone propellers. They are small and can have multi blades but 5 is very rare so the chance it might be suitable for your specific need are small indeed.
Either pick something else to build or find a suitable prop and then design the plane to suit.
Which is exactly what I did with the four blade prop I found and used to build the AN2 in my avatar!
they do exist but are a rare and not popular item so finding them in stock anywhere will be luck of the draw. This is the only one I came across and it is wayyyy to big for that motor. Props for that size motor will be 4 or 6 bladed and even the 6 bladed props for quad motors was only a fad kind of.
The numbers given for propellers are usually for the diameter and pitch. The diameter is self explanatory, It's the length of the propeller from 'tip to tip' The pitch of the propeller indicates the distance the propeller will move forward in 1 full revolution.
I did a little reading up on propellers and the number of blades it seems is in correlation to the torque of the engine. There are a lot of really cool videos on propellers on YouTube.
Hey that's interesting. Seems to make sense. Like American muscle cars vs the cars the young people are driving today. Lower rpm & huge displacement vs very high rpm in a little engine. The big displacement engines - high torque on the driveshaft - would push a heavy muscle car as fast or faster than the light high end European sports cars with high-rev engines.
So high torque engines could spin more blades at a slower speed to get the same thrust.
Another factor was clearance to the deck. Like the Corsair using a four blade prop to keep the diameter smaller.
