F106DeltaDart
You could always toss it in an SKB case and ship it to FT for display....Just sayin.
Yeah.. I'm gonna go with no. I like flying it too much
Thanks for the troubleshooting advice Psy! I did check the alignment with a piece of receipt paper, and it still seems fine for the remaining teeth. No evidence of a sliding motor. I might try to set the alignment a tad closer with this next gear though if at all possible without putting any side load on the motor shaft.Kinda looks like an alignment grind. There are no wear marks on the pinion gear so that usually means the gear mesh worked loose.Did a motor screw slack and the motor drifted maybe? I learned that lessen quick with my nitro heli. Trying to balance the pinion tension with the tail rotor belt tension and not smoke the clutch was a serious balancing act.
Oh and Glad you brought it down safely... Sorry I get scope locked on something and forget the humanity part of posting.. Don't ever get assimilated its a pain at times.
Thanks Psy! Definitely should be an improvement. And without the long “barrel” that slips over the tail rotor shaft, this is rotor is actually lighter! Don’t think I’ll be competing with Goblins anytime soon, but it would be sweet if I could make it capable of some scale aerobatics like loops, rolls, or wing overs. Limiting factor is still that main gear though. Might end up going with some CNC aluminum work there.Wow that looks impressive!
And heavy.
I thought you had a 4 blade hub assembly on that not two pairs offset like that.
As I said IMPRESSIVE.
Having that added 20 degree travel will be HUGE change in tail authority. You might be into full on 3d range control now hehe.
Would be so cool seeing you out competing with all the saab goblins with a Apache hehe.
Thank you for your service! Definitely might have to hit you up on some of the fine details once she is back to flight status. So far, I’ve mostly been working from walk-arounds and other internet photo resources. I am a Flight Test Engineer at Bell Helicopter, which has made it easy to hunt down info for other projects (Huey and Kiowa), but finding info (especially on the A model) for Apaches has been a lot more difficult.Sorry, I JUST saw this thread. I don't know the first thing about making an RC chopper but I have around 30 years working on the real thing so if you ever have a question about what goes on what model or such I'll be glad to help.
