Thanks for all those sources of blades.
No, I saw a really nice scratch-built Allouette at IRCHA with a JetCat turbine on it and all-welded airframe. I had thoughts that I could build one of those, except 600 electric.
That would be awesome! Definitely post a thread if you decide to go forward with that project. I've always thought about doing something similar with a Bell 47, but an Alouette would be pretty unique. There used to be one at my local airport and it was awesome to see fly.
Finally made a bit more progress on the Apache. I got some more paint this morning (as well as snagged a new 550 heli) up at a swap meet in Denton. Finished up the basic paint work this afternoon. Still need to do all the detail painting, but the majority of it is covered. One of the other things that I did was some detailing on the TADS. I had found out from reference photos that the targeting sensor pod and the big sensor on the TADS had a mirror finish. So, I ordered some one-way glass film on Amazon and applied it to some leftover clear plastic. Then I recessed that into the TADS and sensor pod. Here are some pictures of where it is at tonight, took them outside so hopefully it's a bit more visible.
I am debating what to do about the other side on the TADS though. This is where things get difficult. The mold line for that sensor is wrong on the airframe, the bottom should slant the opposite way, and the lense should have 2 separate plates with different angles not a single flat spot:
Is it a small thing? Yes, but for all the detail I've put in so far I kind of want to fix it. Would definitely require some dremel surgery though, so I'm not sure if it's worth the risk. But, the angles panes with some fake cameras behind them would certainly look better than just a piece of clear plastic in the existing spot.
