Then ... at front we dont glue the skin to the internals, wait til the motor/firewall is in place. Also its a good idea to put in servos and pushrods for the tail already.?
One side of the fuselage is done! Adjustment on the start (or type) of tailfin isnt made yet though.
IF some of your gluing of parts on top or bottom lets go.... you havent done enough use of sliding on the tableedge, not made the foam "shapeable" enough!! Thats isnt just something needed, its essential for a best possible nice build.!
Then with the other side-skin, do as done here, start gluing in where section A is, The internal on the scribled centerline on the skin... and on further. Then you will also easy see why the line from top and bottom on the formers are essential. The last skin will go over the other side one. By using the line on formers for reference, you an make a line between the markings made on the skin by the line on formers... Cut at the line, and the skin will fit against the other side skin. Glue in, and go to next part, check where former line is to make reference mark on the skin, cutt, and glue, and so on til ready by bottom & top here too. .
PS! make a bigger hole in the front former bottom, reason is that there the wires from motor to esc is going, and also air to cool down esc, lets say keep approx 10mm to the skin sides/bottom.
Also see that the top of batterybox sides are cut slanted, thats to fit approx the shape of the skin sides + strengthen shape.
