Of course we do .If you want to see the 10 second video, let me know and I might put it up.
Had that happen to me as well also seen on one of my videos .Only got 10 seconds of video. I thought I had 1/2 a battery, it lied and died
Might consider using a lost plane buzzer like this one: https://s.click.aliexpress.com/e/bZKEyEFOThe field you have seen me fly at is overgrown like in the video @mayan showed in one of his videos.
I'm glad you got to fly again! It's been so long. I can see where the change in foamboard would definitely make a difference in the CG. It's surprising how little it actually takes to affect it.Finally got to fly today. Only got 10 seconds of video. I thought I had 1/2 a battery, it lied and died. The field you have seen me fly at is overgrown like in the video @mayan showed in one of his videos.
I had a hard time getting the plane to balance with the new nose. I am thinking that I used foam board from Hobby Lobby first and that is what my Fuselage is made with. The new nose and power pod are with Adams form DT and I think it is lighter. I was noticing a difference when I began using the DT FB, It was cushier and the paper would peal easier. I had to move the battery forward a lot, before I was having to move it back. I think I need to consider sticking to one FB brand on a build.
So late today the wind died down so I went to the field to fly. My first flight was short and I made a good landing. The way the road is I was launching into a cross wind and I almost hit the ground. I had to trim the plane right away. It wanted to go down and to the right.. Got it adjusted while flying, first time I really had done this way. The I came down kind of hard in the weeds. I have to be extra careful and aware, the rattlesnakes are coming out now. I am glad I left the fuselage white, it made it easy to find. During the CRAP check, actually when I removed the wing I felt the servo in the wing was loose so I switched backed to the 3 channel wing again.
On the flight I heard a change in the motor and was having difficulty keeping it up in the air. It crashed on the other side of the field and after going to the area I thought it went down at and starting to crisscross my way back to my truck I found it. The motor had come loose from the firewall. I had 2 screws on it and 1 was missing. I might not have tightened them enough.
Over all, I felt like I was controlling the plane better and I was able to save it most of the time. If I remember correctly I had 3 crashes, 1 hard landing and 3 real good landings. I started with the e-max motor in power pack A and later got the new Flite Test motor. I am not firm on this but I think the Flite Test motor uses a little more battery. I was flying for 10 minutes and now after checking the batteries I think I need to fly for 8 minutes. I need to check this out more so I don't mess up a battery.
+1I still haven't trimmed a plane in the air yet. Congratulations on that one!
I used the Flite test motor on it and the wires coming out of the motor are real stiff for about a 1/4" and that is what lead me to install the way I did. When installing the screws the small ones seemed to short to me and the medium size looked like they get real close to the windings in the motor. When I tightened the screws I was concerned because when I tightened them they felt like the heads where pulling into the holes. I am thinking I will make some adjustments and try it again with the E-Max motor next time. Hope this helps you @buzzbomb & @sundown57I'm glad you got to fly again! It's been so long. I can see where the change in foamboard would definitely make a difference in the CG. It's surprising how little it actually takes to affect it.
I still haven't trimmed a plane in the air yet. Congratulations on that one! I haven't had a screw come out of a firewall yet. I haven't built anything big enough to need four screws. Even the F Pack on the Simple Scout, I only used two. If you're trying the lexan firewall, don't be afraid to tighten it. You aren't going to hurt that thing. Just don't strip out your motor! If it doesn't feel like it "grabs" the screw like the wooden firewall does, that could be an issue. We haven't explored that one yet. Perhaps rough it up with heavy grit sandpaper?
If you're worried that the firewall is the problem, then use a wooden one. Like I said, we (my uncle and I. Mostly my uncle) are still developing it. I just have a bad habit of breaking the wooden ones and he took pity on me. Regardless, thank you for being our first guinea pig! Let us know your impressions, or just drop him a PM. My next few builds are going to have them (including my DR1), I'll let you know how they do for me.
On the video? What @mayan said. Oh. One more thing. Watch out for the rattle snakes! That would be a pretty crappy ending to a good day of flying. Every time you go out, you seem to learn something. Build. Fly. Crash. Repeat. We got that one down. I need to take a page out of your book: Don't forget to learn something along the way!
Nice save .
If it is the screws going directly into the motor itself then use some loctite. I loctite those screws on all my motors.I used the Flite test motor on it and the wires coming out of the motor are real stiff for about a 1/4" and that is what lead me to install the way I did. When installing the screws the small ones seemed to short to me and the medium size looked like they get real close to the windings in the motor. When I tightened the screws I was concerned because when I tightened them they felt like the heads where pulling into the holes. I am thinking I will make some adjustments and try it again with the E-Max motor next time. Hope this helps you @buzzbomb & @sundown57
Hello again, I am back. Been busy with work and a visit from my wife's parents. We took them to the Planes of Fame Museum in Chino California. We had a good time and my wife's dad was in his element. He was in the Air Force in the late 1950's and early 60"s. He was an instructor on the electronics on multi engine bombers. He was telling all about the planes and how the electronics were used on the engines. He will be 80 years old on July 4th. He really enjoyed the trip and it just made me feel real good. Here are the pictures I took.
It made me want to get back into the air again. It is raining now and through the weekend. Maybe if there is a break I can get out and fly. The field might be to wet though so we will see.
Yes it happens to mainly on crashes .Does anyone else have problems with wires staying in the connectors?
