63" Spitfire Conversion
Hoagie mouth
I've had this Spitfire for over a decade but haven't put it in the air. I fly foamies under 4' so this 5lb 63" wing span spitfire is a big jump up in scale for me.
I'd appreciate any suggestions for motor/ prop combinations and servo size. I will likely put the alerons on separate servos but I might keep the tail surface controls as is for now. I'm not really going for a purely scale build and if I manage to not turn it into a pile of match sticks I'd like to eventually add complexity, like split flaps and retracts.
I'm no expert, but trying to stick to scale as best you can is probably not a bad thing...
The real spitfire was built to fly, no? So if you stick to keeping it as close to reality as possible you have the biggest chance of avoiding problems with weight distribution etc.
Bricks
What are you thinking gas, glow, four stroke, electric, standard size servos " (0.73" widex1.52" longx1.32" h on that size war bird will work just fine.
Off-topic jes
Hey how’s the build
