64mm F-106
telnar1236
Continuing my construction of century fighters I got started on an F-106 yesterday. This is essentially just a scaled up version of the Mirage III I posted here a few months ago with some changes to make it into a Delta Dart and a revised thrust angle to fix the biggest issue with the 40mm version. It uses foam board as the primary material and I plan to hotwire cut the wings. It isn't quite scale, but I'm happy with how it looks.
I win with the first reply🤪🤣😋
telnar1236
Forgot this thread even existed to be honest 😆. That photo is as far as the build ever got since I moved on to other projects
Sorry, you're right, that was too blunt.
I just meant that, if the comment was an attempt to bump the thread, wouldn't it make more sense to contribute a thought or say something worth responding to?
You’re right your right.
