Purebredmongrel
Ok after watching both flitetest and experimental airlines, I decided to start construction on my own design of a Pushy Cat with a wider wing span to help with slow flying characteristics. Current weight is 162grams with no electrics (or elevator.) Material is 6mm depron Span is 38 inches.
The wing is reasonably strong without reinforcement other than packing tape. Similar for the body accept for 1.5mm carbon fiber spars in the booms.
I am looking to put in a slowfly prop set up of around 200 to 250 watts. Any suggestions as I haven't had much to do with such small setups before? I can fit upto a 9 inch prop between the booms.
