worst case scenario, use a prop reamer to open the hole on the prop. In that case, you will need to use the appropriate prop to shaft adapter disc that came with the props.
If you do not have a prop reamer, you can try a 3/16" drill bit. Maybe a 1/4". If you use a drill bit, be very careful to keep the hole straight through the center of the prop.
