evranch
Well, all the parts are on order and some have started to show up. So time to put together a build thread I guess.
Components:
- TBS Source One frame
- TBS Source One 7" arms
- HGLRC XJB F438-TX20 V2 Stack FC/ESC/VTX
- Foxeer Monster Micro Pro camera 16:9
- EMAX Stubby pagoda antenna
- FrSky XM+ RX
- DJI Mavic Pro motors, used
- DJI 8330 folding props
- 3s battery TBD as thrust and stability permits
Reasons for selection:
- TBS frame is tough and cheap.
- Camera: good colour and resolution for spotting sheep. 16:9 as I need to see a wide field rather than spot gates at high speed and angle.
- Motors and props: large props for efficiency, folding for pack size. DJI was the only way to achieve this. Used motors are easy to come by in good condition.
- 3s battery: the Mavic Pro ran a 3s battery so it's a no brainer. I already own a wide selection of 3s batteries so testing to find the max weight will be easy.
The motors and props arrived from Ebay. Pretty much as new with a couple scuffs. I wanted to see how they would run with a regular 30A ESC. The answer: Very well. There are no published specs at all, and once secured to the quad I want to gather a bit more data on them.
Remember to always wear goggles and heavy clothing while performing this sort of test. Also, this vise sucks and always comes unstuck from the bench.
Components:
- FrSky XM+ RX
