800mm Supermarine Spitfire Mk I
Nerdnic,
I just finished doing the maiden flight on the 800mm Supermarine Spitfire based on your earlier plans (
http://forum.flitetest.com/showthre...available-by-request&highlight=800mm+spitfire). Great plans, the plane flies very well and she looks awesome in the sky.
The plans are well done and very clear. My only suggestion would be to update the fuselage plans and mark recommended places for the rudder and elevator servos. My guesstimation on servo placement extrapolated from the full sized FT plans turned out correct but I am sure others would appreciate that addition. Otherwise, the plans are first rate.
I kept the power down to keep her a little more scale, running a Turnigy Aerodrive SK3 2826-1240kv Brushless Outrunner at 150 w (
https://hobbyking.com/en_us/turnigy-aerodrive-sk3-2826-1240kv-brushless-outrunner-motor-1.html###) turning an APC Electric 8X4 prop, a Turnigy Plush 30a esc (because overkill is better than the Blue Smoke of Failure;
https://hobbyking.com/en_us/turnigy-plush-30amp-speed-controller.html) and a Turnigy Non-Tech 1300 mah 25-50C battery (
https://hobbyking.com/en_us/turnigy-nano-tech-1300mah-3s-25-50c-lipo-pack.html). The AUW is 521.4 g, wing loading is an easy 13.2 oz/sq ft, and the battery + spinner give her the correct, slightly nose-heavy balance.
After trimmer her out, she flew very well. The elevator certainly has authority and I may tone it down a bit for future flights. I may also swap out the Aerodrive motor for an old NTM 28-26 1200kv motor I have lying around to see if that gives her a little more authority in the air.
I have attached photos of my Spitfire, done up like a Mk I, circa 1940 and the Battle of Britain. As mentioned before, she really looks good in the air.
All-in-all, a nice plane. Well done and Tally Ho!
