Hello all,
My 1.3GHz system from FoxTechFPV.com is set up on the test bench, and I've been able to successfully transmit video from the transmitter to the receiver and view it on an old Audiovox 7" monitor from a dual monitor portable DVD set.
Unfortunately, my camera has not arrived so I've been testing from alternate video sources, such as the Audiovox DVD player from the same setup, and also from an older DV video camera.
But I see that although not ideal, some folks have been able to use an 808 #16 camera as their FPV camera.
I had purchased one of these for the fun of it long before I started playing with RC and I don't intend to use it for my FPV set up. I just want to play around with it until the real thing arrives.
Unfortunately I had misplaced the cables that originally came with the camera and had to order another set, which just arrived.
I connected the 808 in place of one of the other video sources and I get nothing.
I tried connecting the video out from the 808 directly to the video monitor and still get nothing.
So here's where I need help. As I've never used the 808 in this way before, I may well be just doing it wrong. Is there a special mode I have to put it in? Is there a configuration setting that needs to be changed?
So for troubleshooting purposes, I'm taking the entire FPV setup out of the equation. I just want to get video directly from the 808 to a video monitor. Once I know the 808 camera and cables are OK and working and I can get video from it, I can incorporate it into what I know is already working.
So Please Help.
Thanks,
RB
So Please Help.
Thanks,
RB
