90" Flying wing Build - FFW 2017
thenated0g
I wanted to have something big built for flitefest west and came to the conclusion that i wouldnt beable to finish my 200% ft-bronco in time as it has some new shapes i have never worked with before (hot cutting fuselage and tail booms). I have built several flying wings and was confident i could get that done in the time i had. So i designed up a 90" flying wing to hot cut from 2" wall insulation. When im all done i will post all the video i have taken, so for now just pictures.
My plan is to have it break apart into 3 pieces for storage and transport. This first build i am going to make it one solid piece to save time and to make it stronger for "landings".
The foam i am using is 2"x4'x8' and costs around $20. So this is about half of that or $10 worth of foam. The process is similar to cutting out foamboard. I print out the wing templates, trace them on the foam and cut them out with a knife. In this case the knife is a huge electrically heated blade.
For the airfoil i am going to use MH32. I simply grabbed the airfoil, imported it into inkscape and than scaled it up to the root chord of the wing which is 20 inches. Print it out and stick to two stacked pieces of aluminum flashing and cutout with office scissors. Take the stack to the drill press and make holes for T-pins.
IMG_20170402_144601.jpg IMG_20170402_145016.jpg IMG_20170402_145427.jpg IMG_20170402_145903.jpg IMG_20170402_150220.jpg IMG_20170402_150320.jpg
On the airoil is a straight line down the middle which represents the angle of attack. I used a combination square to mark and record this line across the foam. This tool also allows you to perfectly mark mirrored spots on the other wing.
For the center section i took a rectangular block and put the templates on both sides. Than took my cutting bow and traced the templates. For the wing cores i use a pivot point setup. One end of the hot wire goes to a central "pivot". In my case a threaded rod glued into my work surface. Than line up the angles of the lines you drew on the wing so that both sides match up. Also when the hot wire is on the bottom of the airfoil, the wire should be perfectly parallel with the bottom of the foam.
For heat i like to use a 4s battery. It draws about 2.8 amps, so no worries about hurting the battery. The trick is to keep consistent pressure, constant movement, but go very slow....very slow!
IMG_20170404_185736.jpg IMG_20170404_185753.jpg IMG_20170404_185801.jpg IMG_20170405_204220.jpg IMG_20170408_101301.jpg IMG_20170409_195925.jpg IMG_20170409_195941.jpg IMG_20170409_200250.jpg
I am using low temp hot glue for most all construction. For sparing i am using fiberglass kit rods. After inserting the spars i found some extra wood and gorrilla glued them in the back to reinforce the motor area. Than i sprayed super77 over the entire wing and applied uni-directional filament tape across top and bottom and than bi-directional filament tape around the entire perimeter.
IMG_20170408_184846.jpg IMG_20170408_184849.jpg IMG_20170409_140612.jpg IMG_20170409_161452.jpg IMG_20170409_164145.jpg IMG_20170410_193007.jpg IMG_20170411_172634.jpg
To keep up to date you can follow progress on instagram: https://www.instagram.com/thenated0g/
currently in the build it weighs around 860g. I still have to add balsa elevons, maybe a coat of paint, and 5mil laminate over the entire thing. Im guessing final weight around 2.5kg
Mid7night
Jetman
Absolutely LOVE it!! It's like a giant version of my WarWing, with all that strapping tape. :D
Can't wait to see all these things in the air together! :cool:
thenated0g
yeah looking forward to seeing your planes as well. I have something that is going in this plane that will make it extra unique. Should be a good laugh.
Datum
I get the feeling I'll meet people by recognizing planes from the forum. It's gorgeous and I'm excited to see it at FFW!
thenated0g
i ordered an iron on patch for my hat with my social media pic. Probably nerdiest thing i have done. It is strange meeting in person people that you have only know via forum posts.
Michael9865
This is looking great. I won't be FFW2017 to see it but I will follow your Instagram link. Can't wait for the flight reports. Clear skies and Happy Landings!
thenated0g
Use my harbor freight hot knife (top of picture below) i adjusted the depth guage to the thickness of my battery and melted the bay. I did this for all the cutouts. It creates a ton of fumes so good ventilation is a must. The benefit is zero mess to clean up. A little lite sanding to clean up the faces. The battery bay was then lined with bi-directional tape as the bottom of the bay is pretty thin.
I sanded all of the tape on the entire wing and than wiped down with acetone to remove any release compounds so the paint will stick. Than i used krylon for plastic paint to cover the entire thing. Also put masking tape over any foam that was uncovered so that the chemicals from spray the paint do not eat them away.
For graphics i am going to try doing some sharpie graphics using a projector to trace them out.
DamoRC
This is going to look great! What kind of power is this beastie going to need?
DamoRC
thenated0g
Thats a great idea. I am going to be making a v2 that splits apart. I could probably convert this to slope mode with no problem. Remove motor and add some big rx batteries or lead.
JimCR120
Got Lobstah?
Site Moderator
Looks very nice! I don't have the confidence anymore in myself to do all the nice work before the maiden having crashed enough times.
When will you be doing the maiden or have you done it already?
thenated0g
I hear you on the maidens. Honestly the artwork/stickers for me is a break in the work to do something different.
I would love to maiden this before flitefest. But i only have 4 days to finish it. May maiden it at flitefest. Im close. If weather cooperates i will try.
