$ 90 Harbor freight P-51.
Foam Addict
Squirrel member
Hey all!
The other day, I saw a P-51 in Harbor freight. I figured it would be a typical Trashy China special, but when I googled it I found a lengthy thread devoted to this plane. It looked as if a couple of mods and a new RX would have it working.
So armed with a 20% off coupon, off I went to Harbor freight.
Thanks to a really nice clerk, that 20% turned into 25% and I came home with an RTF P-51 Mustang.
After opening it, I found a very well built GWS sized warbird with a 7 cell Nimh pack, a 300 sized motor and some useless 8x3.5? Props.
The radio impressed me. Other than the Gimbals and stickers, I might mistake this for a Futaba 72mhz radio.
Interestingly, the reports of poor range and bad glitches don't apply to the RX in this plane, it's been perfect out to around 1000'.
The foam is excellent. It's very strong, but still cushy enough to "give" in a crash. Kinda like EPP in some ways.
There were a couple of problems, first the motor was not soldered properly and I had to resolder it. Second, the LG snapped when I installed them.
I will give a flight report shortly!:)
lonewolf7717
Harbor Freight Wild Hawk is where this RC thing all started for me. Amazing the mods guys have done to that p-51.
Foam Addict
Squirrel member
Whoops, I wrote that a while ago and forgot to post it.
Ok, the plane is outstanding. No warbird and few planes I have flown can compare to it. It was very locked in, flying similarly to my .40 sized sky raider.
Loops and rolls are possible with all setups, but the stock setup could use a 9x6 prop rather than an 8x6.
I flew it with 4 separate setups today: Speed 400 geared 3 to 1 on 3 cells with a 7x8 prop. (The stock motor and ESC needed some moding.) 800kv 30 gram motor on 3 cells with an 8x6 prop/9x7 prop.
And the stock speed 300 geared 4.43 to 1 on 7 COLD Nimh cells with an 8x6 prop.
The first setup was great, it flew about 40 mph, was mildly aerobatic, and could fly inverted quite well.
The second and third were good, but I preferred the second with the 8x6 prop. With either of these it flew like a glider with zero tip stalling and a tremendous glide.
The fourth (bone stock) setup was actually comparable to the brushless setup with the 9x7 prop. It was not overly powered with only 60 watts per pound but still flew with authority, and was able to pull me out of an awkward situation at low altitude.
This is an awesome plane though, Weak LG not withstanding.
Pros:
Great flight characteristics, only tip stalls if provoked.
Glider like wing loading.
Adequate stock power system.
Good radio, this one I will keep around for a long time.
Excellent foam with a tight bead.
Cons:
Weak LG.
Solid canopy.
$130 price tag when not on sale.( I'd Still pay every penny for a new one if I destroyed it today.)
Needs a minor ESC mod to disable HLVC.
If you like park sized warbirds, go pick up this p-51! It's a great flying plane, and an excellent first warbird on a budget.
bicyclemonkey
Flying Derp
Cool, I see this plane every time I go to China Town, er, Harbor Freight. There's plenty of vids on YouTube on this and the Wild Hawk.
Foam Addict
Squirrel member
I just revised my ideas about minimum power needed for fighter performance.
I thought that the APC prop would be drawing around 7 or 8 amps with the performance I got, but I just checked it and I was drawing a whopping 4 amps static, for only 36 watts! Granted, I came in 4 oz lighter than the list weight with all the stock components except the landing gear, but still, that only gives the plane 41 watts per pound, and it was capable of loops with a dive, rolls of all types, and beautiful stall turns, as well as nice ROG and a 20 degree climb!
Anyway, I added a few mods for convenience, including a steerable tail wheel and larger foam wheels. image.jpg
She's not perfect, but I love her!
Foam Addict
Squirrel member
A few more stats:
AUW stock: 14.3 Oz
AUW speed 400 with 3 cell 1000: 15.1 Oz
AUW Brushless with 2 cell 2000: 13.4 Oz
Stock prop, stock battery: 4.2 amps at 8.1 volts, incapable of flight.
APC 8x6 prop, stock battery: 4.3 at 8.1 volts, flies well on the wing.
HK APC style 9x6 stock battery: (Will edit in when it arrives)
Unfortunately it only has 5 flights, and all but one were belly floppers due to 12" of snow.
With the air scoop on the belly I wouldn't belly land this plan in any thing but deep snow or tall grass. I even lost my prop in a greased landing where it just dug in to the snow and snapped the prop shaft on my brushless motor.
Foam Addict
Squirrel member
Ok, it flies just a little differently now.:cool:
The good:
After a few epic fails as far as replacement power setups, I installed a 2826-6 and a 5x6.25 prop, on a 25 amp ESC and a 3 cell 1000.
Can anyone say, "FunFighter."?
I'm guessing it tops out around 80-90 MPH, and has about a 3-4 min WOT flight. Best of all it's only drawing 12 amps to do it.:D
The Bad:
My wings had about 80 degrees of Dihedral if I pulled any G's at WOT (to their credit, they didn't fold). So I added a strip of Extreme tape wingtip to wingtip. It has almost zero flex, and flies way better now.
Oh, and the Ugly?
I snap rolled it HARD about 6 feet off the deck flying in a snow storm today. I didn't even break the prop.:p
Foam Addict
Squirrel member
Ouch, this left a mark... The motor screws came loose from the backplate, ripping up the upper fuselage. As if that wasn't bad enough, the shock evedentally damaged the RX antenna. It was losing contact sporadically on the way back and promptly glided into a fence post.
Anybody know how to fill gouges in EPO?
xuzme720
Dedicated foam bender
If it's gouged, try lightweight spackle. If it's dented, sometimes warm to hot water can bring it back into shape...
Foam Addict
Squirrel member
Thanks X, I will try to find some spackle.
I had another idea I don't want to reveal until I figure out whether it works or not. I'll keep you posted.
Oh, not bad for 36 flights eh?
I also have a second one that might be here in a week. I can't wait!
xuzme720
Nope, not bad at all! The hot water thing might work on the nose where it's a little wrinkled...
And make sure that you get the lightweight spackle...
You'll be able to tell the difference when you pick up the tub of lightweight, it will feel empty!
Foam Addict
Squirrel member
Yeah it had some major issues, the spackle worked great, but the second coat of black paint just puffed the foam really badly. I found some GWS corsair stickers that covered the worst damage, but it still looks awful.
If I get this other one, I'll sand the damage off this one and fiberglass it's nose. The other I can keep stock.
xuzme720
Sorry, I should have asked if you were going to paint it. Best to use on that type of foam is water-based paints, such as craft acrylics. Anything with a solvent in it is bad news for most foams. EPP seems to be resistant but almost all the others are allergic to any sort of solvent.
Foam Addict
Squirrel member
Well, a friend decided that flying into my path when I was flying around 90 mph would be a cool idea... It looks like trash after that crash :/. Thankfully, another friend traded me his brand new P-51 for two Blu-babies. :p
So here it is:
It has a 2826-6 motor rewound to 6/7 turns y terminated. It's really efficient with this setup, drawing about 9.5 amps at 11.7 volts on a three cell 1000 and 8x6 prop. What's crazy though is that the flight times are insane.
I was flying getting the rudder trimmed out, and snap rolled it in and broke the prop after about 2 minutes. Then I switched props, and took it up again for around 10 more minutes. When I landed the motor was cold, and the battery was at 11.3 volts.
It is just an awesome plane, don't over power it, keep it light and stock, and it will never cease to please.
Corbarrad
I felt tempted to buy one of those if it didn't come bundled with that horrible 72 MHz radio. The brushed-with-gearbox setup was also a major detriment.
It doesn't have the nicest lines among all the warbirds out there, but its compact and without the TX it might be a nice relaxing flyer.
Edit: Almost forgot, I got a pair of wings for this plane sitting around that I snapped up for 5 bucks each at a clearance sale a few years back... possibilities, possibilities...
xuzme720
Just swap out the radio and motor combo and sell them on eBay. Someone out there is looking for that kind of equipment and it will help ofset the cost of your upgrades...
Foam Addict
Squirrel member
The Radio works awesome. It has a 2-3000 foot range and is a very nice radio. Better than the DSM2 junk I've been dealing with. (Not a spektrum hater, but my P-51 was severely damaged in a brownout today)
CavalierX
Just caught this and I am excited at the possibility this plane presents- I have ALWAYS wanted a Cadillac of the Sky. My grandfather was building gas powered planes in the 1930s and always wanted to be a Pilot. When WW2 came he went to enlist in the Army Aircorp but was Medically DQ'ed because of a rib dissection from a bout and Pneumonia that nearly killed him at age 9. He served in McCarthy's Army as a part of the 39th General Hospital- but his head was always in the clouds. I clearly remember him talking about the P51 when I was a boy. When I was a kid I build gliders and hand launch planes with him from balsa, cardboard, and foam trimmed off of Egg Cartons. 40 years later- liquid and with a little more free time (just a couple weeks ago) I bought an Apprentice 15e and Maidened it the next day 5 take off and landings, only one nose down (I blamed the bumpy grass on the field and a loose front gear) and a full battery later I was HOOKED. I am excited to start building foamies and share this hobby with my son. That said.
I am going to pick this plane up- I am excited about retro fitting it. Would the Flite Test Spit "the BEEF" kit from Lazertoyz make a good swap-out? Perhaps with an Orange Rx and my new DX5e? I can't wait to see this thing ripping through the fresh spring air.
http://www.lazertoyz.com/Swappable-Spit-Powerelectronics-pack-THE-BEEF-_p_441.html
Foam Addict
Squirrel member
It would work, but it would be really heavy. This plane really needs a 370 sized, maybe 400 sized motor. Think 100-150 watts.
It will even fly on the stock equipment and a 9x6 or 8x6 prop! (50 watts)
Above that you can bend the airplane. I used the turnigy 2830 1100 KV motor, but I would recommend something in the range of a 2822/2208 1400 KV motor.
http://www.altitudehobbies.com/brushless-motor-370-28-26-1450kv-suppo-2208-14
http://www.hobbyking.com/hobbyking/store/%5F%5F36719%5F%5FD2822%5F14%5FBrushless%5FOutrunner%5F1450kv%5FUS%5FWarehouse%5F.html
A 1000mah 2-3 cell works well, though for duration a 1500 will work.
This is a really great plane for just simple warbird aerobatics or evening cruising, and looks awesome in the air too!
Ps. Don't get ORX. Some people claim to never have issues, but my p-51 with an r 600 browned out last night and went straight in. It survived, but I don't trust ORX at all any more.
