Manual
Alert Tones
The SPEED PASSION “SKYWALKER” ESC is equipped with audible alert tones to indicate abnormal conditions at power up.
If ESC can't enter into working mode after powering up, it indicates that you have not setup throttle calibration.
2. Continuous beeping tone (****) – Indicates that throttle stick is not in the minimum position.
3. Single beeping tone followed by a one second pause (* * * *)– Indicates that the battery pack voltage is not within the acceptable range. (The ESC automatically checks and verifies the battery voltage once the battery is connected).
4. A single beeping tone followed by a short pause (* * * *) – Indicates that the ESC is unable to detect the normal throttle signal from the receiver.
Built-in Intelligent ESC Safety
Powering up the ESC for the first time and setting the Automatic Throttle Calibration
The SPEED PASSION “SKYWALKER” ESC features Automatic Throttle Calibration to attain the smoothest throttle response and resolution throughout the entire throttle range of your transmitter. This step is done once to allow the ESC to “learn and memorize” your Transmitter’s throttle output signals and only repeated if you change your transmitter.
1.Switch your Transmitter ON and set the throttle stick to its maximum position.
2.Connect the battery pack to the ESC. Wait for about 2 seconds, the motor will beep for twice, then put the throttle in the minimum position, the motor will also beep, which indicates that your ESC has got the signal range of the throttle from your transmitter.
