You bunch of dirty pervs'!
Haha, everyone wants it to stay naked! I don't think that it will be very good for orientation as is, so I'm definately going to paint it.....sorry.
Got a few wrinkles in the ailerons. More due to my bad design than bad covering technique or material. But it'll work.
Got the servos/receiver in place, pushrods done, I think now it just needs the undercarriage and some paint?
Here's the wing with all done with separate servos
I'm also doing some electrickery experimenting with this plane. I now have one of them new fandagled 2.4GHz radios (ok it's the $30 Hobbyking radio) which has computery stuff inside, so I've set up a mix (well 3 actually) which will give me flaperons. So the theory is that I use channels 1 and 5 for ailerons and have them function as normal until I spin a knob which dials both ailerons down (or I can preset the knob and then flick a switch to activate) while still maintaining the differential movement when I move the Tx stick. That way I can dial the amount of "flaps" quite easily on the fly...pardon the pun.
So I should be able to slow it down nicely....we'll see.
Weighs in at 880g with the wheels and UC sitting on the scales as well, so all I'm missing is paint and a couple of screws......did I just say that out loud?
Pretty good for a 1180mm WS stick with a 2650maH 3-cell on board. Should float around easily.
Servos easily fitted.
nice straight run for the elevator.
