cdfigueredo
I've been checking the fuselage and I think it's very weak. The foam I use is not high density, so the 5mm sheet is too fragile. I've decided to build the fuselage the way I usually do.
Then I will cut it in half and dispose the electronics properly inside. The original model uses rubber bands to fix the wings, instead, I will use screws as I usually do.
I will try to make room to place the power pod, otherwise I will attach the engine to the fuselage directly.
