A new hot wire cutter build thread - One cubic meter volume
NM156
For some crazy reason I decided to build another CNC hot wire cutter. This is going to be much larger than the one I currently have. It's going to be one cubic meter in size. I don't plan on cutting anything that large, but the dimensions will provide a steeper cutting angle and allow cutting more parts in a single run.
The frame will be primarily be 2040 extruded aluminum. I'll be re-using the electronics box from the current hot wire machine. It will be configured to use both a tension spring and bow for the wire itself.
In a total overkill decision, linear motion will be guided by MGN12 rails.
There will be two frames (X/Y and U/V axes) mirrored to each other. 1/8" aluminum will be CNC milled into the necessary brackets and mounts. 3D printed parts will round out the build for additional bracing, foot mounting brackets and wire management.
I can make all of the STLs and DXFs available if there is interest.
Let's get this project rolling...
Cutting the aluminum parts.
A little bit of cleanup on a Scotch-Brite wheel and these are ready.
In the background the 3D printers were cranking away making more parts
Mounting brackets for the feet
Making wire management clips
Corner braces (gyroid infill)
FlamingRCAirplanes
View attachment 219522 View attachment 219523 View attachment 219524
Lets goooo!!!!!!!!!!
NM156
Now that I have some basic parts created, I can start the assembly.
3D printed alignment tools for 12mm rail to 20mm extrusion.
Attaching the MGN12 rails to the extrusions. The alignment tools help center the rail over the extrusion.
I prefer the slide-in tee nuts as opposed to the drop in type and use them when possible.
Internal corner braces (Most for assembly convenience, the load will be carried by the Aluminum and 3D printed brackets)
I had them on hand, so I'll just use them...
The basic layout of one side frame. The final orientation is vertical. The X axis will be driven from both the top and bottom by a double shafted NEMA17 motor. This helps avoid racking caused by driving only a single side. GT2 belts will be used,
Y/V Axis attachment plate to the X/U axis
I had to use drop in tee nuts here, I'm temporarily out of slide in tee-nuts. I'll replace these when I replenish my supply.
Awaiting the double shafted motors for the X/U axes drive. Expected to be here Tuesday.
Flange bearings arrived today and also the shaft couplers for the motors. I couldn't find any 5mm to 6.35mm couplers with a quick delivery, so I ordered some 5mmx5mm adapters that I'll chuck in the lathe and open up one half to 1/4".
Started printing some more parts tonight, more 3D braces for the bed and some GT2 belt joiners.
Tomorrow I'll CNC the final 4 pieces for the X/U drive, and cut some aluminum angle for the Y/V drive connections. Then I should be able to connect all of the subassemblies.
FlamingRCAirplanes
Man this is beautiful
Flightspeed
Convicted Necroposter
So is this basically a diy version of what Flitetests been using for the b17? Have you ever used that kind of foam or do u use the pink stuff.
NM156
That is correct.
I've used several different types of foam. The white stuff (styrofoam) tends to be more convenient because it comes in many different densities. The pink and blue are usually available in a single density (as and insulation) and are typically heavier.
