A place to post plans and planes
Wildthing
Hope this helps. For the elevator, 2 .031 wires through the tubes (left side) and an .055 wire off the servo arm joined together with a linkage stopper . Right side is the rudder. I have linkage stoppers on the control horns for final adjustments.
sundown57
that's kinda what I came up with. I have some .030 tig wire that I use for pushrods and I used a wheel collar to hold the 2 rods together. I did have to do some mods on the front. not having a 3D printer i just doubled up on the first and second supports and made a mini power pod and it worked out well.
Wildthing
Nice, that should do the trick. Make sure everything is tight on the top end, once the upper wing goes on no going back ;) .
sundown57
here is the power pod and how I put it in. I'm starting on the wings now. do you have pictures of where the 2 spars go and how did you get all 4 ailerons linked together
sundown57
