quorneng
Many WWI planes used a "rotary" engine where the whole engine went round with the prop. Such a feature is very rarely modelled usually using just a few dummy fixed cylinders and then only those that are visible.
A very long time ago I built a couple of "small round the pole" (RTP) WWI planes (Fokker Triplane & Sopwith Pup) using geared slot car motors driving big scale props that also had a scale(ish) rotary fixed to the prop shaft.
Both planes actually flew well but despite my attention to scale detail I carved a conventional CCW prop which is wrong for an Oberursel rotary as it rotates the other way. Ooops!
With the advert of powerful light brushless motors with LiPo batteries and light foam construction I wondered if this concept could be used on a scale RC plane.
For the first attempt I modelled the little known Fokker V25 prototype.
For the time, mid 1918, it was a remarkably advanced concept using a Triplane fuselage and a plywood covered low wing. A layout for fighters that was not adopted by others for about 15 years. It was however rejected as it was felt the low wing unduly restricted pilot downward visibility. Fokker solved that issue by mounting the wing on struts above the fuselage. This layout was accepted and put into production as the Fokker DVIII in the last couple of months of the war.
My RC Fokker V25.
Small and light (sub 250g) built entirely from 2mm thick Depron sheet the 2805 motor is the rotary's crankcase with the cylinders simply stuck on to the motor bell.
It used a 8x3.8 prop but still with an incorrect CCW!
Hand launched it flew OK but was extremely sensitive and every landing resulted in a nose over.
With the advent of 3D printing I considered trying a bigger version of the V25 with a true scale Oberursel UR-2 rotary.
First make the rotary as true scale as possible.
The A2212 1000kV is buried in inside the crankcase.
The rotary is clamped to the motor by the prop driver. This arrangement does allow it all to be assembled & disassembled.
The rotary, its LW-LA cowling and a 12x6 prop mounted on a test stand.
Running at full power on a 2200mAh 2s.
And nothing came off!
Interesting that with the cowl in place the "windage drag" from the spinning cylinders is significantly reduced giving a noticeable increase in rpm.
Maybe not every ones "cup of tea" but it does look impressive.
Now all I have to do is build the plane to fit it on!
My RC Fokker V25.
