very nice. did you add the rudder to the vector? it really turns it up a notch and makes cobras, hovers, high alpha's and all sorts of 3D stuff possible.
Nice maiden! Congrats! It looks like you had it dialed in pretty good. That was some nice flying and a good landing. The bomb drop? Hard to see, but still cool. It made the FT3D look like a torpedo bomber. Too cool.
Thanks a lot this is the 4th plane I e ever flown and I was a little intimidated by the flight characteristics but she handles great! Plus it was a easy build, couple hours maybe. Ya it's a great plane next build will be the edge for sure!
The edge is fun! Mine on the old c pack and 3s was underpowered, but with the motor you are using, you should be good. Might want to step up to 4s sometime though...
Well @Salmonslaya here it is! Maiden will hopefully be tomorrow. It doesn’t look as good as yours, but it should still fly well. I plan on flying this thing hard so I don’t want to put a lot of time into it😂 Not sure why I did this to my edge then...
Well @Salmonslaya here it is! Maiden will hopefully be tomorrow. It doesn’t look as good as yours, but it should still fly well. I flan on flying this thing hard so I don’t want to put a lot of time into it😂 Not sure why I did this to my edge then...
I hope to be able to tomorrow. Hopefully taking the EAF Edge, Spitfire, and the SOG4. It'll be maiden for the Edge, that will depend on how bad the wind is.
Or pause the bipe and build the Edge. You could probably whip one out in a couple hours. Then after you've flown the EAF, you'll have a baseline to compare your bipe to. You could even move the same powertrain from the EAF to your bipe.
