Ace GLH 250 - My first balsa build!
Grifflyer
WWII fanatic
Hi all,
I will be attempting my first balsa build, by building the @Willy Nillies Ace GLH 250!! I chose this plane because I'm currently lacking a fast prop plane in my lineup, and there was a build guide for the plane on Willy Nillies youtube channel.
I was having lots of fun so I didn't take a whole lot of pictures, but here is the fuselage almost complete.
So far everything has fit together really well, and I've had no problems so far, although I would like the tolerances on the slots for the tabs to be a bit tighter but that's just me:D
I'll probably be asking lots of questions so be prepared for that:p Like what is a covering film hinge? The instructions recommend using a "covering film hinge" for the elevator.
vhandon
I created a build log for the GLH-250. Maybe it can help.
https://forum.flitetest.com/index.php?threads/willy-nillies-glh-250-assembly-guide.60522/
A covering film hinge is simply a piece of covering ironed on the bottom and top of the control surface. If you have built an Armin wing then the procedure is similar. An overlap of about 1/2 inch on each surface should be enough for this plane. I start by applying the hinge on the non beveled side (usually the top) then actuate the hinge up and apply the other side. This allows for free travel.
Grifflyer
WWII fanatic
Thanks!
Joker 53150
Mmmmmmm, balsa.
Something I heard from a kit cutter in the past, the cutting could be perfect if it weren’t for the balsa. From sheet to sheet, or even within a single sheet you’ll find thickness variations that can make slots and tabs either perfect, loose, or tight. Normally this is only a small issue.
Good work so far on your kit!
Grifflyer
WWII fanatic
Alright so I covered the V stab. It came out really good, and I was surprised to still be able to see the wood grain whenever I held the part up to a light. I did have one problem though, It appears that the colored part and what I'm guessing is the adhesive sheet separated. It happened on all of the edges of covering, but this was the biggest (all the others can barely be seen)
Does anybody now why this happened and how I stop it from happening? I'm just going to put a small piece of covering material over the white part to hide it...
Willy Nillies
What kind of covering is it?
99.999 % of the time there is a plastic protective sheet that MUST be pulled off the colored part before you apply to structure.... I'm guessing this is your problem.
Sincerely,
Doug and Becky
WillyNillies.com
Willy Nillies
Ok, I re-read your post more slowly...🥴. If the clear plastic is lifting and red color is staying on the part, your iron is too hot.
Sincerely,
Doug and Becky
WillyNillies.com
Turbojoe
Okay thank you!!
Doug is right. Iron is way too hot. I do the same thing all the time. I know better but just never seem to learn. Depending on the covering sometimes good old isopropyl (rubbing) alcohol alcohol on a paper towel will clean off the color/adhesive smear. Other times I have to use acetone (nail polish remover works too). Also try using a "sock" on the iron.
Joe
rockyboy
Skill Collector
Joe
I've heard that thin toddler socks work just as well as special made covering iron socks too - haven't tried it yet, but plan to with my next covering job since my old sock is pretty well colored in!
Turbojoe
Yep, I've got a nice stash of my grandsons baby socks. I pull them tight to the iron shoe and use a zip tie to hold them nice and tight and smooth. If they're not tight they can lay over and create nasty wrinkles. If you don't have a baby or grand baby to steal from Goodwill would probably be a great place to score a mess of them cheap.
Joe
Grifflyer
WWII fanatic
I'm using a big clothes iron so I don't think a sock would fit, I'm just going to keep messing around with the temperature until it works. How long should you need to apply heat before it starts shrinking?
rockyboy
Skill Collector
Try making up a little frame of balsa or scrap wood and experiment with covering pieces on it - or cut little strips of covering and drop them (adhesive side up) on the iron to see how they react. Personally, when in shrinking mode (after everything is stuck down to the frame) I like to have the iron hot enough that the covering starts shrinking after 2 or 3 seconds of being on the iron. If it starts shrinking immediately it's too hot for me.
I'm a hair dryer fancier for shrinking since heat guns get way too hot. Unlike @rockyboy, I only use the iron on the millions of wrinkes I get after shrinking. I used to use a gas stove, but THAT worked out well(NOT)
TooJung2Die
I've switched to a adjustable heat gun for shrinking. The iron is mostly used for tacking down and sealing edges. The iron has to be in contact with the film for best heat transfer. That can be hard to do with a large clothing iron but I've covered airplanes with one too.
