Thanks! It's a little time consuming to build this style, but it's really neat to see it come together
On that note, here's the vertical stabilizer and rudder all ready for covering - sanded to shape and hinge blocking in place. [Edit: now that I'm looking at the picture I realize I need to add some support for the control horn too!]
Back on the horizontal, I swapped ends with the leading edge piece, swabbed with ammonia, and bent it into shape for a night.
Then today I pulled it out of the form, added glue, and pinned it back into shape. In a couple hours I'll be ready to add the trailing edge and internal framing.
And I made a little more progress on the motor pylon. It's got too many weird curves to easily cover at this point, so I'm thinking to paint it. Started that process by spraying it with a couple coats of polyurethane to protect it, gave it a light sanding, and glued on the firewall with epoxy and put it aside to dry for a while.
I know I'm going to have some trial-and-error ahead of me to get the right motor angle, but I'll do those adjustments with washers behind the motor mount.
