I just got the Eachine Wizard x220. It has the Spracing F3 Flight controller, now. That said. I got everything set up and ready to go. I turn it on and go to hover, then it insta-flips and goes crazy (never left the ground, though). I had to use the failsafe to get it to stop. So, I checked everything again and retried. Same thing.
I took it back and created a log, calibrated the ESCs. checked the motor numbers, and the motor directions. All were normal. So, I decided to run it from the TX while it was on betaflight. I moved the throttle a little, and saw the problem.
As soon as the throttle goes up, motors 4 and 2 start spinning up to 100 percent, and wont turn off until I drop the throttle to zero.
WHAT IS GOING ON?
WHAT IS GOING ON?
