wadsie
hey, i just bought a turnigy 9x and a tech one angel.
i have hextronic 9g servos
the problem is that the ailerons dont work, the servos dont move at all, when i first pluged them in only one moved, then we swapped the y cable (home made) around and that didnt work so we swapped them back and now they dont work at all.
so has anyone got any idea or a sugestion on why this is happening
thanks
colorex
Rotor Riot!
If the y cable is home made, you might have gotten something wrong, or you might just have a bad connection.
StoneKap
Executive Producer
Admin
thanks
Plug in each servo to the RX without the cable just to see if they work.
ananas1301
Crazy flyer/crasher :D
Yeah do that first to make sure if they work at all!
Also show us a picture of your homemade y cable so we can see the connections you did. Also I would love you if you can show us some pictures of the tech one angle. I really love the plane and if I could I would buy it but I prefer building stuff myself instead of buying everything.
lobstermash
Propaganda machine
If you've got a 9x, and your ailerons are on separate servos, I'd take advantage of the channel mixing rather than use a Y cable anyway. Then you can have flapperons!
wadsie
The elevator ch2, the rudder ch4, and motor ch 3 all work ok. the ailerons servos ch1 don't work at all. Then I removed the y cable and just plugged one of aileron servos in ch 1, this still did not work. Done the same to the other aileron servo and no action also. I then plugged one of the ailerons into ch 2, ch4 and still didn't work. so seems that both aileron servos don't work at all.
I check ch 1 on the receiver by plugging the rudder lead in to ch 1, but this still didn't work. so it seems ch 1 on the receiver is not active. so maybe the receive is a dud.
After trying this all again, the servo I was using to check the wiring now has stopped working.
Does anyone know what i am doing wrong or does it sound like I,ve got faulty equipment.
looks like I will need to buy 3 more servos and a receiver.
can anyone send us a detailed wiring diagram for componets I am using.
see below details of, servos, receiver and ESC
http://www.hobbyking.com/hobbycity/store/uh_viewItem.asp?idProduct=15202
http://www.hobbyking.com/hobbycity/store/uh_viewItem.asp?idProduct=662
http://www.hobbyking.com/hobbycity/store/uh_viewItem.asp?idProduct=12339
wadsie
see attach photos of tech one angel and y cable
ananas1301
Have a look at this.
You have a built in ESC so just ignore everything in the circle as it is stated:
Diagram on RCG
I just saw your picture!
Your y cable looks kind of weird to me. I only see 6 cables going into 2?
If that is the case that is wrong.
Could you probably tell us what wire you connected with which one when you soldered them?
In a very unlucky case you might have damaged your servos with the y cable, which you actually didn´t even need at all!
CHELLIE
be very very careful with the plug/wire polarity on the receiver, if you get it wrong, you could burn out your receiver or esc, you have a ground, signal and battery wire, they all need to all be in the right place on the receiver, y connectors are Cheap, if you did not get the wiring right on the y connector, you could have burnt everything up, its not worth trying to make your own connectors, most of the time, people cause their own problems with reversed wiring, and that becomes costly, Take care and have fun, Chellie
colorex
Rotor Riot!
This looks like you have the positive and ground wired together. I would say you are burning out your channels. A proper Y-harness would have everything in parallel:
White - White
Black - Black
Red - Red
You may need a new RX.
Yes, what Chad said. You probably thought the other servo would be reversed by reversing the polarity. This is not so. To reverse a servo you need a servo reverse, OR plug the ailerons in two channels, OR turn the servo around and move the control horn to the opposite side.
Unfortunately, you may have damaged your servos and receiver.
wadsie
yer we reversed the polarity on one side os thats where we went wrong, so i think we need a new rx and servos
pgerts
Old age member
As you say - you may have damaged the things - but...
It is normally safe to connect a servo the wrong way.
The + is in the centre to make it safe (almost).
You will "normally" not burn anything if you change so the signal and ground (minus) are exchanged.
You will of course not get any function if the plug is wrong.
But if you are moving the centre wire (plus) to one of the sides then it will most likely be damage.
jetpackninja
More combat please...
I think this is likely what happened. Take a close look at the homemade wiring connector...
