toryander
I understand that you can mix controls (rudder with ailerons and such), but I've checked and I see no elevator/aileron mix. I've just installed an aura board (took me hours due to my noobness). I'm using the preinstalled Aura model in my Pocket ERLS Tx. I finally got everything working on my MightyMini when I noticed the airlerons were working in tandem with my elevator control. The ailerons work normal (with no elevator involved) when using aileron control. Like I said, I've checked mixes and see none. On the Aura I have 1. Throttle, 2. ailerons, 3. nothing, 4. Elevator, and 5. Rudder. I have my ER4 plugged into the SBus pins to the side coming from channel 2 of the rx (elevator). I'm beginning to think this is the problem, but I'm not sure what to do about it. (I plugged the SBUS into channel two of the rx because that is where I finally discovered the Aura will communicate with the rx). Sorry for the messy question. I'm seeing a connection between channel two on the Aura ( ailerons) and channel two on the RX (elevator). Not sure of a course of action.
