Ailerons in the Pietenpol?...
Hi all, has anyone fitted ailerons in a FT Pietenpol? I know the guys at the field will berate me for building a 3 channel 'plane.
Martin
Tonero311
I'm working on it at the minute. Regular sized ft pietenpol with straight wing and flaperons. Just waiting on a new receiver then I'll maiden.
https://forum.flitetest.com/index.php?threads/aileron-guidance-needed.59191/#post-483306
There's the link to the one I'm working on. I'm still unsure about the size I've cut the ailerons, i think 1/8 of the wing shord might have been a little too small, but this is a test bed and wing will be easy to swap as long as I can land it in one piece.
jfaleo1
I would add differential (more up than down movement) and be prepared to coordinate turns. But should work fine. As a rule ailerons do not need to be the size of those on 3D aerobatic planes. Look at the ones on a J3 cub (full size) for reference.
Tonero311
I was flying a old style B pack motor(emax CF2822) with a 8" prop, 30 amp esc and a 3s 1500mah battery.
All of the above was too heavy, big or powerful for the airframe. It was so heavy it had a high stall speed, so put slow flight out. Too much throttle made the air frame torque roll due to the motor and prop combination. Because the battery was so big too I had to make stays for Velcro straps between the wheels for the battery to sit. Only way I could get CG to balance and this had a negative pendulum effect on the handling too. Small 55mm wheels guaranteed a nose over every landing too.
So this was my second build using the correct components this time. Just ailerons, 2 extra 5g servos, 5a ubec, 65mm spoked wheels and strengthned landing gear fairing is all I changed. Hope it flies beautifully this time as this one is 100-150g lighter and it is an eye catching model.
Tonero311
A few photos of the original and results of first crash due to not having a clue what I was doing😂🤣 was my first RC Plane and build.
  • Like
Reactions: FDS
1500 is a HUGE battery for a mini. I top out at 850mah and as light as possible. My SE5 has still ended up in pieces even with minimal weight.
You can use a single 3,7g servo with torque rods for the ailerons, my SE5 has two 1,5g micro servos on the ailerons. They work but possibly are not big enough, as you can’t turn entirely on them, most of my turning is still on the rudder.
Most of the minis still fly better as 3channel, especially the multi wings. You want super light construction, small motors and batteries. That makes for great flying. If you want more build something bigger!
Tonero311
Yes, think it was your advice last time @FDS I based my new power set up on. In regards to battery and esc size. I was going to go with a 12a and you advised me the 2204 motor may need a bigger one to go 20a to be safe. Went with the 850mah 3s battery too. Sound advice, worked perfectly with my FT-22 mini today. Expecting the same to work here as well.
Thank you for the help.
  • Like
Reactions: FDS
Well, I think that's as helpful and conclusive a set of posts as I could hope for, gents. Many thanks. I think, as I have just bought a larger cub kit from an old friend over the 'net, I will save the ailerons for that one.
Cheers,
Martin
I wonder if anyone can tell me what these bits are in the Pietenpol kit. The black bendy straw and the white flexible foam with clear tape either side.
Also does the "power pod" go in this way up (open part upwards)?
Many thanks,
Martin
Tonero311
The straw is for a faux engine hose between radiator and engine. Bbq skewers for wing braces and power pod skewers and small fake spark plugs on the engine. Velcro is for battery and possibly esc. The wire is for control rods. Open end up on the power pod. Makes a nice little cavity in there i tucked my ubec into. Hope this helps.
Ah, the top hose! Never thought of that. Skewers I get and control rods (although there are 4 of those). So the white stuff is Velcro? I must check that out. Thanks.
My son is 3D printing an engine and radiator for me...I hope...I sent him the file.
Cheers,
Martin
Tonero311
The pietenpol is finished and awaiting maiden. Had to add nearly 100g of nose weight to get it to balance with a 3s 850. Tried a 3s 1000 but because it was longer and flatter that worked out needing more dead weight again. On the plus side though placement is all very neat and tidy. No more wires hanging near the prop.
Programmed in flaperons on a 3 position switch as well. Seems to work fine on the ground so far. There's a few videos on YouTube for it on a Flysky i6X. Uses all 3 mixes so hit the first limitation on this Transmitter so far.
Happy flying everyone.
Tonero311
Just had the maiden. This wee plane flies wonderfully. Plenty of power for it to climb. Elevator felt a bit weak, but I'm trying to bank and yank it about like my FT-22 and it's not working great. Definitely need to get used to balanced rudder control now. Didn't get testing vertical climb ability though I don't believe it is lacking in this regard given how easily it climbed in altitude. Ailerons work perfectly with full throws, nice and gentle. Next one i'll double their size. Flaperons on the other hand may have worked if they weren't reversed. Lol. First landing put full flaperon on to discover my plane gaining speed on descent. Bent the landing gear and took a wheel off on that rough landing. Easy fixes.
Plane flew again straight away without flaperons this time😋. That's when I decided the wind was too much just yet for this bird(about 10mph).
Pack up time and off to fix the landing gear and flaperons direction. Happy flying everyone. Hopefully get out again later with my new modded mini FT-22, but for today the Pietenpol is grounded.
Fujimo
thats excellent news Tonero!
what were the dimensions of your ailerons, and what would your proposed improvements be, as i will be adding them to my new build.
did you use the standard 5g servos that came with the flight pack for the ailerons?
many thanks!
