hreehoorn
I don't have a lot of good experience with wings and I just built a Goblin at 130% and I was skeptical of the build to begin with, just cuz it ended up being so heavy compared to anything I have built before just to balance it. I flew it and did a stall test and I will show you what happened here, I was so surprized, check it out at 6:28 and about 7:20
Now I actually added a third set of rates since this maiden where what used to be the high rates is now mid rates, and the now high rates are the same as the mids but I have maxed out the elevator at 125% just for short soft landing. If you don't have the space or an endless supply of props this would save you. I took it out today and the high rates trick worked amazing, no broken prop. And if you land in a head wind it will hover all the way to your feet. It reall isn't that hard to do, both sticks full back all the way to the ground, a little flare at the end. Good Luck
Thanks for sharing man! I flew a few goblins at Flight Fest Texas last year and while they aren't technically a wing, they are damn close and I felt behave a lot like one. So your input is 100% valued to me!
