Marzipan
1 hour? No problem. This can fly power on for a theoretical 5 although 2 hours non stop is the longest I have even done!
I agree with LitterBug entirely about conventional model EDFs. They are designed to give the maximum possible thrust for a given fan diameter rather than the best thrust to Watt performance which is exactly the feature required for a quad.
Note the Airbus E-fan actually uses what is in effect a multibladed prop in a short duct rather than a fully buried fan emulating a turbojet installation.
The latest turbo fan airliners with their huge fans are actually closer to a ducted prop than a conventional EDF so using a quad motor and even a 4 blade prop in a duct can fit inside a scale turbofan nacelle.
A 3x3.5 (76 mm) 4 blade inside a scale airliner duct powered by a 2205 drone motor.
The duct, motor mount and pylon are 3D printed with the nacelle exterior in Depron.
Of course it only gives a fraction of the thrust of a true 76 mm EDF but it only weighs a fraction and only uses a fraction of the Watts. Its thrust/Watt is over twice that of the EDF.
It just so happens this is a scale nacelle for a RR Trent as used in the Airbus A350 so it just has to be built light enough to be able to fly on the limited thrust.
Everything sacrificed for minimum weight so its hand launched and belly land, carefully!
It weighs 652g with a 1000mAh 4s (try running two 76 mm EDFs on that!) with a combined thrust of close to 500 g.
A lot of effort and it is about as delicate as the full size but it does fly more to scale than most EDFs.
https://www.youtube.com/watch?v=b8ZGijxUhL
