Thanks. And you're welcome.The plane is looking great - really clean. And a big thanks for the SkyBench website!!!!
Strength wise it probably doesn't matter where the holes are. Aesthetics would suggest you should glue it to the shear web. You could use a connecter but I would glue it....CA maybe
I'm not a fan of the thin stuff either.You could also give a little wire wrap, tape, tie a knot, hot glue, canopy glue, or shrink wrap too.
But if you use CA, don't use the thin stuff. Ask me know I know.
Now that I have had success putting threads in a wooden block, I want my Olympic II to have bolt on wings. I will have to use metal screws for bolts though because to make a threader, I need to use a metal screw that is identical. I also have heard that nylon screws break if they aren't maintained.
This is the threaded block I made easily today.
