Alt-Aero, an Aeroscout inspired rc plane
HappyRCFlyer
I started with the specs for the Aeroscout and made it my own from there.
This has one of four different wing configurations now, compatible with the original Aeroscout and my own, Alt-Aero, hot wire cut foam based Sport Wing with this compliment. It did require a 7" prop and higher motor placement for correct flight, the gear itself, nothing special, standard cheap Park Flyer gear upon. It's as a kit, pretty simple to do but does require assembly so none of that I'm going to remotely go into RTF format for offering in that regards at the Happy RC Flyer website.
Test flight shared here upon, I kept it mostly at 1/2 throttle:
Handling is easy, predictable, no bad tenancies and I even had it flying hands off the sticks in part of this video. Weight, around 25% lighter then the original Aeroscout, durability, an absolute tank in comparison and super easy to repair, there will be no need to have to re-order a new airframe regardless of how bad the person crashed it. Will it win contests on looks, nope but then again the original Aeroscout will not either, will it do it's job as a trainer, and learning more advanced flying, certainly. Still, there is no SAFE or other gyro based systems forced upon the pilot, nor is that even needed, I was not even using a computer TX for the test flights on it, just go easy on the sticks and nudge it along.
Costs, well, it's less then buying a new wing or fuselage, you can opt for this with the entire kit of a new plane instead, you still have to get your gear to throw in "or" transfer over from the original, it's an economical way to get into this world along rc planes, even if you are deciding to opt out of the endless replacement fuse, wings, etc. of the model it was inspired by. I'm also showing the specs/files for it's lighter version that can be ordered for those more advanced and not needing as much of a tank along the fuselage tail boom, etc.
