Alternate method to attach wing to Tiny Tutor
robtarr
I have a Tiny Tutor that I want to put a camera in to get used to flying FPV. I'd like to put the camera basically in the "cockpit". I can cut out the front window and the camera fit pretty nicely in there. The problem I'm having is that the skewer used at the leading edge of the wing to attach the rubber band is blocked by the camera. Any thoughts or recommendations on alternatives for mounting the wing? I thought about building in some vertical tabs on the bottom of the wing a little bit further back, and run a skewer through those and the fuselage. I also considered moving the skewer down below the camera and extending the rubber band further down (I don't love this idea).
Any ideas would be greatly appreciated. Thanks!
Foamforce
Another possibility is that you could just put in a new skewer below the windshield. The rubber band would then start at the normal place behind the wing, over the top, and then down a couple inches to the lower skewer.
Or, glue a skewer on length-wise, below the wing, extended out past the wing a little bit.
First idea in red, second in blue.
Eh?
