Solved Alternatives to the EPS-350C motor
I am going to make the BluCub2 and it needs this EPS-350C motor which looks like its gears are rubbish as they are plastic. Secondly, I can't even find them so I want to know if there are any alternatives to this motor. I will put the PDF which has the plan which can also be accessed on the web page.
Thanks,
RC Soarer
SquirrelTail
SquirrelTail
Hi SquirrelTail,
How would I mount this kind of motor on my plane? The reason I ask is that it has a specific guide on how to mount it.
I would go with the stock motor mount block they were using but get rid of the stick. I would cut a piece of 1/8" plywood to the size of the mount then screw the motor to the firewall that you just made.
