If it works, I would like to try building it with DTFB!!
Firstly there are to be 2 versions. The first is as described above, (3 mm FB), and will be the Kulula, (Named after the owner - Ku and of course the Alula which inspired it) and the other is to be in 5 mm FB and around 1400 mm wing span which will be the Kelula, (Kel is the owner and the Alula of course).
As for flying they both did and the balance is a tad more than 25mm back from the wing LE where it glues to the nose/fuselage. Took them both out today when the wind was blowing quite strongly at times but direction was a little erratic. Also managed to use the bungee for a few launches, (around 10), and the speed and climb were surprising but the weight was a little too light for the conditions.
The earlier version with the thick wing did fly OK but not as well as the thinner wing version so the thinner wing version will be the one subject to plans being drawn up!
Ended up nosing the Kulula into the ground about 5 times, (often at high speed), before the nose was finally destroyed. My fears about the wing strength were answered when one launch ended up with a roll and a high NEGATIVE "G" loop which launched the ballast weight, (Out through the hatch), way beyond the flying area boundary into the bush where it remains. Even flew with an additional 60 grams of lead ballast to improve penetration and whilst it did sink a little quicker it still flew quite well.
So now I have to make 4 Kulula, (1 with motor power), and 3 Kelula, (1 with motor power). Sadly if I want one I had better add it to the list soon!
Based upon today's efforts I may be adding a little additional reinforcement to the nose area BUT the wing spar, (even using 3 mm Balsa) is way stronger than required and so a FB spar should suffice!
Just one note of warning! The bird can be very pitch sensitive due to the light weight and the massive elevon area. It was still flying and fully controllable at less than walking pace when the wind died away!
In addition the LIGHTING which is a similar but retail offering also flew but it could not handle the conditions anywhere near as well and it definitely could not survive any more than 2 nose in landings. Actually it made the Kulula look way superior in all aspects!
Anyway that is all I have to report except that i will now go and build a new nose for the Kulula and perform yet another repair on the Lighting!
Have fun!
