L Edge
Did you know that if you spin the props to the outside on both wings, it helps it roll much better!!! 3 other transport guys tried the same and agreed.
Will be interesting in the sound and airflow reaction(thrust) of your bird. Did it with a set of 5"x5pitch props on a fighter plane and it worked out okay at high speed and rpm's. I wonder what would happened if using large slow flying props was the case.
