Have you seen some of the balsa plans on outerzone? There are notes for almost every piece sometimes all over the place, and how would you know without them? I like alot of notes on the plans.I'm sure when people look at my plans they may be a bit overwhelmed. I like to keep notes on the plans - all over the plans. Little thoughts here and there, options that some might want to implement (or not, such as the flaps). My thoughts and ideas of making the assembly a touch easier. At this point I want to make the front of the cowl a lamination of like 5 sections of foam board with the paper removed from both sides and then have the builder sand the cowl to a nice rounded shape, but I also think that someone might think I'm nuts and not want to do that - "just give me a darned former to roll up and make the front!" I'll probably do it both ways as I continue to develop different methods (like gluing the wings with gorilla glue instead of hot glue... thank you @SSgt Duramax I think) and trying to be nice to those that have already decided on how they like to build. And here we conclude tonight's episode of "The mad and non-sensical ramblings of a tired individual at 2AM...."
I do like outerzone - I love just surfing the plans sometimesHave you seen some of the balsa plans on outerzone? There are notes for almost every piece sometimes all over the place, and how would you know without them? I like alot of notes on the plans.
This project is looking great. I would be satisfied with your first simpler P36, but this is going to be a beauty. Im a fan of all the Curtiss Hawks and I would like to have at least one of all of them in my hangar eventually. https://en.m.wikipedia.org/wiki/List_of_Curtiss_Hawk_aircraft
Btw have you seen the 3d printed dummy radials on thingiverse?
https://www.thingiverse.com/search?q=+radial&type=things&sort=relevant&page=1&category_id=95
If you build a wooden one you gotta post it here! I'd love to see it! The Ki-27 might be in my radar for a design and build coming up one of these months...There's an export version of the P-36/Hawk75 with a fixed landing gear. May be an idea for a model that can take off and land.
I'm barely starting rc-building and flying. My current enterprise are training on the ez-jets that use the ez-stem power pack, but I'm feeling the urge to go to my scrollsaw this afternoon and cut me a Chinese air force fixed wheel Hawk 75 wooden toy and a Ki-27 Japanese along with it.
I just love old.airplanes, I guess
Here’s a thought. I’ve got a Sea Fury that I built, and I’m planning on doing an improved V2. I’ve realised I can probably make a better set of skins by fitting paper templates over the V1 plane - paper is easy to adjust and I can make those fit perfectly on the plane before transferring them to foam. Haven’t tried it yet, but could you do that on this one? Lovely looking plane, by the way...Well the weather here has been rather uncooperative. It was finally quite calm, but it was also 12FI really want to see how it flies before going much further
Oh well - tonight then brings tinkering more with the one PITA skin near the front. I glued the top on and it sat much closer than just the tape and it proved to be too far off as it wrapped the sides that I got wrinkles - and we can;t have that. SO I peeled it off after making my notes again and back to plan mod, print, cut, test fit ... repeat, repeat, repeat
Also working out the foam board version of the hatch/cockpit skins and fitting. I will continue to do the plans with an option for a clear canopy build as well, which makes the formers and parts just a bit bigger. Options options options! And lots of notes on the plans![]()
I've gotten used to doing a half template of each part in foam board then scanning it in. It has worked great so far on most parts. Its just that this one is quite interesting in how it needs to bend...Here’s a thought. I’ve got a Sea Fury that I built, and I’m planning on doing an improved V2. I’ve realised I can probably make a better set of skins by fitting paper templates over the V1 plane - paper is easy to adjust and I can make those fit perfectly on the plane before transferring them to foam. Haven’t tried it yet, but could you do that on this one? Lovely looking plane, by the way...
Yikes. I can see why that one might be tricky. Good luck! Judging by how good your prototype is looking I think you've got this!I've gotten used to doing a half template of each part in foam board then scanning it in. It has worked great so far on most parts. Its just that this one is quite interesting in how it needs to bend...
It ends up having pretty good slopes in different directions as it molds around the formers and it is a pretty tight fit to boot. I probably would be better off learning some 3D cad to do it but this old school method I find rewarding and relaxing.![]()
Things are going together well, but I'm getting impatientI need to be sure I get all of my little tweaks notes transferred to the plans! I also ended up accidentally using an unmodified skin so the gaps are a bit much. I will not be painting this one or else I'll never end up doing a second build to check all of the mods
I figured out the pushrod locations as well. Two more skins to go (one of them in on like version 6,664,123,341 (actually only version 7, but it feels like the first number
) View attachment 216232 View attachment 216231 View attachment 216233
I'm talked with some people that don't like those crazy servo mounts and opt for the drop in method. I know its much easier to cut a rectangle than whatever you would call the shapeIt's looking really good already! Those seemlines don't seem too big from these pics (except maybe the one under the front skins but I can see you're working on those anyway. Split flaps, tail-servo-push-rod-straws for neatness and I dream of one day cutting slots for my servos that are as neat as those haha!
I'm talked with some people that don't like those crazy servo mounts and opt for the drop in method. I know its much easier to cut a rectangle than whatever you would call the shapebut these wings just don't have the depth otherwise. They aren't hard to cut - just a sharp knife I guess. Perhaps I'll do a video on how I go about cutting them out...
I even have a cardboard pattern to trace them in when I'm prototyping
well look at that, I'm an influencer... so if I want to say add split flaps to my P-40 (I was going to just do hinge flaps, then I saw yours and said YEP that is what I am doing) ...
Looks great, that is pretty much how I was going to do the flaps. I like the servo tunnels. Probably a ton easier to run the wires through instead of them bouncing everywhere.another suggestion is to put a backer for the servo in the deeper section of the wing before folding. With the wing bottom on the bench and the spars already glued in, place the servo in the hole and push down tight to the table. Cut a piece of DTFB to span the spars and lay flat on the servo. then just glue the edges. That way you don't need to fiddle with blocks or whatever when you go to install the servos. (pic from BF109 wing, backer is like an edge box but you get the idea)
View attachment 217235 View attachment 217236
also don't want to forget my servo wire tubes. I made the ones in the P36 with just paper rolled double thick. The 'tubes' let you install the servos and wires after you fold everything up. Just fish an extension through, plug in the servo, and pull back through.
