Antenna/vtx location 5.8Ghz
lobstermash
Propaganda machine
I'm having a writers' block type thing with my Bixler and 5.8Ghz vtx... The last two sessions, I haven't been happy with the placement. First I had it behind the camera, where I used to have my 900Mhz vtx, but the antenna doesn't get enough height. The antenna wasn't near high enough and video was less than perfect. Next I moved it up in front of the motor. It was great at lower altitude, but get up higher and when on the way home, video was getting way too much shadow from the plane.
What's the best spot for it?
Nonamerc
Arman
5.8 GHz video transmitters are hard to place because it does not penetrate EPO really good. Below the wing is indeed the best place but I dont think it's really that easy. Also it does not matter if your antenna is upside down if you are going to mount it below the wing..
lobstermash
Propaganda machine
Put it under the wing (extending down past the fuselage) with a servo so you can retract it before you land :D
Thanks Andre. That is inspiration! I might just do that! Now to figure out the retract mechanism...
I was looking at the vertical stab, and the wing tip, then below the base of the wing, then further out on the wing.
I guess ideally it'd retract out the bottom of the fuselage, but if the mechanism failed I'd be in all sorts of trouble!
KKArioKA
Epoxi Flyer
thats a good question !! where is the best place for it ? are you using clover leaf and skew plannar ?
does antenna extensions for the clover leaf affect the signal ??
lobstermash
Propaganda machine
I'm using a cl on the vtx. I've also only got a short antenna, because I made it out of the stock one. I've made up a little mechanism with a servo and some balsa. The vtx sits on a balsa plate and is lowered/raised on the gear switch. It seems strong enough on the table (and shaking the plane in my hands), but some field testing is needed on this. I've placed the vtx about 10cm out from the fuselage under the wing and the antenna just protrudes past the bottom of the fuselage when lowered.
I think re antenna extensions, it's better to extend the video wire and move the vtx, as coax absorbs some energy as radiowaves pass through it. But then I've seen lots of 900 and 1300Mhz systems that use a long antenna extension to mount a vee or cloverleaf on the vertical stabiliser...
Edit: Hope I can keep this thing as aerodynamic as possible... I've been forced back to the stock motor and a 5x5APC prop - will also need some field testing
lobstermash
Propaganda machine
So here's what Mark I looks like:
glydr
How many letters do we ge
Reminds me of... a spoiler.
When I flew full size gliders we used those to decrease lift.
Just an observation.
lobstermash
Propaganda machine
Yeah, it'll create some drag. I should have shown front on too. It doesn't take up much more area than landing gear would. I'm going to see how it flies and make modifications as needed. As I said, Mark I. Mark II will be parallel to the wing I think. I didn't expect the servo to move as far as it did, so I straightened the antenna a bit. I thought the tx would sit at a 50 degree angle or so and not kill so much airflow.
While I was playing with the Bix, I also removed the velcro holding the wings together and put rare earth magnets where the ends join. They didn't quite meet, so I put another magnet in between them and it's now a pretty solid connection. It'll be nice having the inner part of the wing for lift again.
Carbon
Elemental Madness
Very creative lobster! When speaking with IBcrazy he said that it is ideal to put the vtx out on the wing, not on the fuselage, if you are planning on flying further away. If you are staying low and fast like he does it is ok to fly with it on the body.
Great work, I can't wait to see how she flies!
lobstermash
Propaganda machine
Thanks Ben. I pretty much just ran with Andre's suggestion and it really was that easy! Three cable ties, a couple of pieces of balsa and some hot glue.
lobstermash
Propaganda machine
Can you move it out on the arm behind the camera? The main thing you need to make sure is that the body of the tri doesn't block the line of sight between the antennas.
bmsweb
When you say the video was less than perfect what do you mean and at what range? I know I'm good for 3 klms with mine and if you use a directional antenna on the ground station, no reason why you can't go out to 25 klms.
lobstermash
Propaganda machine
I was getting it cutting in and out, especially on the way home, even around 400-600m. However if I flew lower (<100m) or not directly toward or away from myself, the signal was good enough to get out past 1km pretty comfortably. My antennas are pretty short, because I made them out of the stock ones. That's probably half the problem. With the retractable antenna I should be clear and crisp. Just have to test it out now...
bmsweb
That's really strange because I'm using the 100wm FatShark 5.8Ghz system on my Mini Skywalker and the video is pretty solid within 1klm. I don't know what the range it because I've never gone beyond the 1K mark with the Mini Skywalker. Only time I have issues is when directly over my head, which is expected with the antennas that we use. I assume the antennas you're using are built for the Channel you are using?
In any case good luck with it, looks like a very interesting idea :) Nice work
lobstermash
Propaganda machine
Haha, no, the antennas are nowhere near precision! It's very much from the RCModelreviews school. I used 1mm copper to make up for my lack of build skill and equipment to fine tune it. I initially made them for the relay between the 900Mhz system and the goggles, but I ended up getting a good deal on a 600mW 5.8 tx and tried them out. They work better than I thought they would but because they're so short the signal gets blocked by the plane very easily.
bmsweb
That's interesting because I've never had a signal blocked by the foam on the aircraft. Even on my bixler where 90% of the time that antenna is blocked I have no issues at all.
lobstermash
Propaganda machine
I based my initial antenna position on your setup too! I'm extra keen on testing this out now... There is a distinct possibility that my antennas are, er, sub-optimal.
Nonamerc
Arman
My friend had that to with his skywalker, the vtx was behind the motor and when he returned he almost lost his video. He had no problem before making the turn....
