OK, new question. how common it is to melt the Teflon tube? Is this something I should buy a lot of or did I do something wrong? Last night I get it up to run a 16-hour print and it failed about 2 hours into it. seems the Pla melted to the Teflon tube and stuck there so it stopped feeding material.
I think the only time I really had grief with it was after printing abs at 270 degrees and then when I went back to pla I started having issues. I think part of the issue was the nozzle starting to plug up which put more back pressure inside. I changed the teflon, nozzle and even the shaft plus hotend
I did replace it once before but it had a lot of miles on it and wasn't sealing between it the shaft and the nozzle anymore and I was actually getting filament through the shaft threads.
When I bought the printer I looked what 2 bit piece can crap out and make me sit idle for weeks. I ordered extra packages of nozzles, shafts with teflon in them , hotends, a stepper motor and the little brass gear on the extruder motor.
