any way to reset ALT on a osd?
smittyplugs
any way to reset the ALT on a osd?
My osd is reading ALT:662 when on the ground the speed is correct at 0 any way to calibrate the ALT on the gps or osd..im working with the hobby king G-osd II
thanks Smitty
lobstermash
Propaganda machine
Hi Smitty, have you figured this out yet? I've got a g-osd on the way and have my programmer ready to re-flash it to cl-osd. Apparently this fixes most of the bugs with the system, I think including the altitude.
lobstermash
Propaganda machine
$4.75 from HK. If you're just buying it as a single item, you're better off getting one from ebay, but if you've got an order with HK with a spare 35g, this is well worth adding. It took some lateral thinking to get the drivers to work with Windows 7, but once that's done it's easy to reflash anything with an ATMEGA chip.
